I have been searching high and low and can't find a good video or a good step by step on how to sync the carbs on my 1500. I had the carbs rebuilt by a rep vendor and feel they did a great job but they could only set it up on a bench. I feel certain they are out of sync. the issue I am having is once it's warmed up it has a healthy hesitation on the low end until you get close to 3K when under a load as in taking off it wants to stall unless you crank the throttle, but once it's moving it does good, the hesitation is still there but not enough to stall the bike. it pops a little on decel but not bad
it will idle good and has strong accel when just sitting there. also it seems to run worse when to motor is cooler. this past weekend we were in the mountains and when we would drop down in the valley it would start hesitating more. I added some pre filter foam over the intake horn and it will run a little better but still hesitates at low end. I am getting a sync kit but need a good guide to go by to get it right. any help will be greatly appreciated
