1 - 2 of 2 Posts
I tried to synk the carbs on my trike this weekend.
I let it warm up, then hooked up the gauges.
The left gauge read 17# The right read 15# when I tried to adjust it I could make the right side worse but could't make it better.
Am I doing something wrong? Or do I have a vacume leak.:?
THANK'S
[line]
Senior Guru
hi doubleeyes you could have a small leak but in order to sync the carbs you need a clean air filter and good plugs try to tighten the rubber isolators they have been knowen to cause a leak over time and acording to the manual once its with in two hgv the sync is ok but give the other a try first one more thing the starting base line for the sync screw is three full turns out
1 - 2 of 2 Posts
