Does anyone know what years will swap with regard to GL1500 diffs ?
Those that follow the Tech. forum may remember this gem: http://tinyurl.com/l79b2q
Well. I still have the problem, and I don't want to get 500 miles from home and have a failure that could potentially lock the rear wheel and kill us both.
Things have been loosened and retorqued several times while turning the wheel- with, and without weight on the diff. Things have been apart, cleaned, tire and wheel bearings replaced.The drive splines look like new on both the coupling, and the diff. Still the noise.
The only thing left back there that turns at the same speed as the wheel is the ring gear.
Differentials are pretty cheap on eBay, but seem to be resold without being installed quite frequently. I've looked on the Honda Parts fische, and numbers are all different for complete assemblies.
The only thing I can tell from eBay pics - is the drive spline count on a '96 appears to be 26. The part number is visible in the pics, but doesn't match anything on the fische.
Has anyone stuffed a later diff. under an '88 ?
