Look at the upper triple clamp which is hard to see a lot in there under the tupperware . The extension should be screwed into the top of the fork tube . If it is extended you should be able to see/ feel the joint where the extension fits into the original tube . Check just below the upper clamp area .
The extender may require the use of a spacer to keep the spring in the correct length . If so that would need to be removed .
