Somewhere I have seen a convenient crossover T tubing connection setup forthe front fork tubes.
It's a bit tedious to get the 6 lb air pressure balance between the 2 tubes and with a tube connecting bothair fittingswith a single input it would be easier.
Has anyone else seen this optional part?
Other side of the pond
I don't recall seeing this on any GL1500's, if they are available I'd love to know about it as well.
I did see one once, the single air connector was on the left side coming out of the crossover hose. If I can see it around I'll pass the info on.
Can't see any harm in Y connecting the fork air supply. You'd have to remove the shrader valves from the valve stems first and put on on the common end of your Y. It works okay on the rear end when you have dual air shocks like Progressives.
