To find out whether or not your bike's forks are equipped with air valves, check under the fork caps and you should see an air valve there. If it does, they only require a small amount of air to pressurize them to run in the 6 -14PSI range. A small bicycle pump works well for this.
As for the harshness, I am betting that your fork fluid needs changing out and flushed, followed by the correct amount of some new15w, or 20W fork oil. Might want to check that the anti-dive system is functioning properly as well.
Dusty
Dusty
