1 - 11 of 11 Posts
Does anyone know the chepest place to buy a fuel pump for a 1988 GL1500?
Other side of the pond
Are you going with OEM or one of the aftermarket ones from eBay?
would like to have oem
Would like to know if using the Honda Accord fuel pump on the 1500 is a good way to go? Looks like a easy fix.
The Accord pump will not last long. Try a NAPA pump #NFP P72190. I have an Airtex #E8371 but it is like the Accord pump. The stock pump puts out 2-4psi. and 10gal.per hr. The NAPA pump is ratted at 4psi. and 15gph.
The Carter P72190 is much cheaper than the NAPA and is the same pump.
Our attempt to fix a 1500 fuel pump with the NAPA pump resulted in 200 good miles, then it died.
Couldn't get $$ back because it wasn't used for what it was made for....automobile.
Went with the OEM from someplace in Flordia for about $270 delivered to our door.
Bite the bullet and get the correct pump....problem solved.
I bought mine from the guy that markets the new replacements on ebay. So far its worked great....Installed it back in Feb. No problems at all. Cannot say the same for the rebuid on the the petcock though.
Ditto, on the petcock rebuild.
1 - 11 of 11 Posts
