If you move wheel back and forth by hand w/Wing on center stand& in neutral, it MAY be excessive play in ring/pinion gear[had this condition onold GL1000]. If this IS the case, look around for someone sellingrear end after Trikinga Wing. They usually unloadrear partscheap; savesa lot of $.
It COULD also be a rear end bearing going, even though they look OK[ Putnew wheel bearing in both wheels back awhile, as sidecar rigs aretough on them. Cost me $79.20 total at a local bearing dealer].
If it's something else, other very knowledgeable folks here will advise, I'm sure. TTFN.....Old Tom
