· Registered
I just bought a gl1500 w/ sidecar. I started it yesterday but Today it wouldn't turn over I hooked my battery charger with a 30 amp starting mode
The lights work but won't turn over. Did I possibly burn out a main fuse
Or fusible link.
· It aint rocket science
The starter doesn't crank, correct. Is the neutral light on? If not try cycling the reverse lever a couple times to make it light. Try starting with clutch lever pulled in. With the key on and CRUISE ON button activated does the cruise on light illuminate. Kill switch on? Does the headlight cut off when starter button pushed?
What year is it?
Start simple. Kill switch? Neutral? As it's new to you, 2 clicks on the key. 1 click will turn on lights, but you need the key straight up and down to start.
