hi all I am looking for a pilot screw wrench or D socket. with out getting for mother honda. also trying to find a portable tachometer . :baffled:if you know were I can find them, would like the info thanks in adavence
Senior Guru
http://www.gunson.co.uk/item.aspx?item=1822&cat=668hi if you have a look at this gizmo it will be more presice than the taco click on the english version and it will explain it for you they are avilable on ebay for a few bucks i made my own tool from a lenght of 4mm aloy tube drilled out the inside a little bigger and it fitted just nice and thight just off hand if the carbs were not messed with the setting will not go off line you only need to reset if you changed the jets to a different size or somebody messed with them before
old has been wrote:
hi all  I am looking for a pilot screw wrench or D socket. with out getting for mother honda. also trying to find a portable tachometer . :baffled: if you know were I can find them, would like the info        thanks in adavence
my 93 has the same "D" shaped screws. i wondered if there was a tool available.
Robin
Senior Guru
the tool from honda is part no 07LMAMT8010A
