Please help! I have a 1996 1500 SE with about 91000 miles on it and I have owned the bike about 2 1/2 years.
About 6 months ago my alternator went out and I installed a compufire alternator and a Westco SVR sealed battery. Before I replaced the battery and alt. I was having the "start on button release" starting problem when the engine was cold and after I replaced them the "start on button release" pretty much stopped.
Now the starting problem is coming back getting harder to start.
The charging system is putting out between 14 volts to 14.5 volts. The battery before I even turn the key on is about 13 volts or more. While cranking the battery voltage drops no lower than 12.5 volts. This problem only occurs the first time I try to start it normally in the morning to ride it to work. What could it be and could it be a vacuum line or in the en richer (choke) or even tided to my second problem?
My other problem is after the engine and exhaust warm up it backfires in the exhaust after I let off the throttle and down shift. I did see some post about this problem and a deceleration solenoid but I have been unable to find them. I even tried to find the solenoid on Cycle Max's OEM parts but no such luck.
Please I need some help. I ride almost every day back and forth to work. :?
raying:
Thanks Everyone
Philip
Thanks Everyone
Philip
