Really you can kinda get a "look" at how it works by looking into the side fins on the fairing: The inlet sides of the cooling fans are "sealed" with a foam weaher strip to the rear of the radators; and the oulet of those fans blow right outta the side fins (with the fans off, the airflow follows the same path). Looking into the fins, turn a bit to look rearward... you'll see where the lower vent there is ducted into the same space as the side fins (try placing a lamp near the outlet of your heater vents, and look from the fins side to find the light when the vents are in the "H" position (lever=downward). The heat vents are just an alternate airflow path 'out" from the rear of the fans...
I seem to remember hearing of a test once where someone measured the outlet air temperature from the "heater" on a fully warmed bike ... I believe that the "increase" in temperature from that measurement was less than 10*F over the ambient temperature... so if you're in 20*F air, you can 'hope' to open the vent to push a volume of up-to 30*F air past your shins
There is a noticible difference, though I don't think you'll ever be ridin in shorts and getting 100*F air outta the vents, but allowing a smaller amount of air to be exposed to more heat does help increase the output -- Especaially at a stop where the fans kick on
I mentioned the "weatehr stripping foam above -- the fan-to-Radiator, the fan duct-to-fairing grille area, and the fan-duct-to-heater vent are all sealed with a lightweight foam tape product... this stuff will age and allow for air leaks -- Leaks will allow cold (and hot) air to mix where you prolly don't want it to mix, again -- not much to be gained, but worth replacing that tape the next time you're inside the fairings with access to the fans or inner faring ducts. (in summer, good seals will allow the fans to be most effective and also to blow the heated air OUTTA the side fins...)
... but as above -- really not gonna be a world-warmer manage your body warmth, airflow, and think about supplimenting your body's warmth directly (electrics)
