1500 rear tire change
1777 Views 8 Replies 5 Participants Last post by  D-Rod
G
I know there are posts on the forum on how to remove the rear tire on a 1500?
I cant find them.
Can someone help me?
Need posts.:(
1 - 9 of 9 Posts
Here are a few
1500 Rear Wheel Removal
www.goldwingfacts.com/forums/forum1/23281.html
Changing a GL1500 Rear Tire on the road
http://www.goldwingfacts.com/forums/forum1/75270.html
1500 Rear Wheel Removal - and loosing a tire spoon inside the wheel
http://www.goldwingfacts.com/forums/forum1/69215.html
That's all I have bookmarked for now. I also moved this thread to the technical forum, so all the threads will stay in one place.
G
Thanks az.
I knew there were posts but couldnt find them.
All you have to do is remove the left muffler,put her up on a motorcycle jack, remove axle nut and losen pincher bolt,axle spacer & washer.
Back the left shock bolt out ( do not remove) enough to allow the brake bracket to be moved to the rear of the bike past the frame and pull the wheel off of the shaft toward the left of the bike and straight down and off she comes.
Click on my photo bucket and view some photo's I took of my rear tire change.....
G
Thanks kyboy
AZ last two links don't work :(
Okay, I took out the titles and made the link direct so you can see them. Corrected the first post, and here is how it looks now.
Here are a few
Left saddlebag is all I ever remove so that the caliper will pull out of the way, and swivel the left muffler down.
1 - 9 of 9 Posts
