Does anyone know how to remove the mirror on a 1999 model 1500 SE-Anv Goldwing???
Pull the rubber boot away from the painted trim and you will see three Phillips screws in the mirror mounting. One screw at the top, two at the bottom. They are a tad awkward to get to, you can bend the mirror fore or back on its swuivel to get easier access to the screws.
mr irrelevant
The rubber boot needs to be unhooked from the mirror trim ring, the boot just sits in grooves on the trim ring, once u have that done unclip the trim ring from the fairing. The mirror screws (3) should be visible once the boot has been moved, and to aid in the removal of those the mirrors flex forwards and back..Once those 3 screws are out mirror should come right off..
I had the same question about my 97 Asp and found this Topic with a quick Forum Search. Thanks.
Lex
Also look in the Reference FAQ section as there are helps there too and in the main menu is the GW Tips.
