1 - 3 of 3 Posts
This morning one of my throttle cables snapped. Luckily, it happened in my garage rather than on the road. Anyway, I am trying to find a procedure to replace them (I figure I will replace them both while I am at it) and am not having a lot of luck. If I can avoid pulling the carbs, that would be ideal.
Does anyone have a procedure for this?
Thanks,
The Fonz
Anti-Guru
you shouldn't need to pull the carbs at all -- the cables run to a mixing box across on the left side of the bike (easy way to find the box is to follow the cruise-control actuator cable). All under the left inner fairing.
I'm sure someone will be along shortly with a good link to a procedure.
Now, be sure and lube all your cables, throttle, reverse and speedo every year to help prevent this from happening again. Next time might be on the road.
1 - 3 of 3 Posts
