My friend who does not use a PC has a problem with the tilt switch on his 1989, 1500 import. The symptoms are 1. bike cutting out when he hits a pothole, catseye etc. 2. if you shake the handle bars with the engine running, it cuts out. It can only be restarted by turning off/on ignition switch.
Are these replaced under warrenty even at this late stage of the tilt switch saga?
