Are there any noticeable symptoms of a timing belt needing to be replaced?
How often shud the antifreeze be changed?
Timing belts don't give any warning signs when they are due for replacement. They can look fine and break a week later. Coolant is supposed to be replaced every couple of years, but you can get away with longer.
Thank u. I was told the belts were replaced 30,000 miles ago. He also said a couple of other things were done which he actually SAW had been done, so had no reason to disbelieve the timing belts weren't done.
I appreciate the reply.
Oh - THAT guy...
My belts were at 81,000 miles when I changed them, but should have done them a bit sooner probably. They looked fine. I think they were the stock ones. I hit a deer in '05 (about 20k on the bike) which caused a lot of damage, but I do not remember Honda charging me for belts and I KNOW they would not have done them for free. Even if they had, that was still 60k on the belts.
As for coolant, the entire system only hold about a gallon. I like to do it every year, two years at the max especially if it sits. It does not take a lot of scale to reduce cooling ability and changing it is VERY easy, not to mention cheap.
Oh - THAT guy...
As for your signature, I find the 1500 the easiest to ride of the wings I have owned. Just do it.
Of course, my massive bulk helps (I am 5'10" and weigh in about 155 pounds)
