221 - 240 of 256 Posts
Discussion Starter #221
i have mad a wooden frame to carry the body,while i repair it , also it will be handy for the mould making process,
also painted the back end black , just need to make up an exhaust , thing is i can not go under the wishbones as the backend is very low, so i need to go over the drive shafts(axle s )
:sadguy:Barry, Where are you?:sleepy:
going over shoulnt be a problem wish you had goten tail pipes of a dual ehaust at pull aparts the you would have the bends ready. but I have faith in you.
looks good so far.
Yes where are you Hope your Doing OK!!!!!!!
how does it ride with the stock honda shocks? is it stiff with the 2 coil overs on it?
Hi Barry.I joined the site today(wed 10th nov). Ive just bought a GL1500 to trike & Im very interested in the fixed axle trikes youve built using the air suspension.I presume it was the trusted Reliant Axle which ive already bought.I got so much greif from other users on lesser sites over the fact that "you cant use a solid axle with suspension without it seriously affecting the handling.It has to be hard tail". I dont suppose you have any plans i could use or even a few close up pics i could get some ideas from. I would be forever in your debt. Wanna make it a bolt on to get round the MSVA laws. Regards,Tink
Hi welcome Tink,Barry not been around for a bit.Am using a ford axle with proggresive shocks and the handlings fine,am using Tri wings bolt on kit.
Think the standard reliants axle would require gear ratio change to suit goldwings performance and engine revs.
Hi Big Al. Cant run to a kit mate. Its all gonna be a self build. Already got the axle & ive seen a Few wing trikes using the reliant axle but,they`re all hard tail. I need mine as a soft tail due to disability. Ive built a few hardtail reiant trikes & a couple of cx500`s. This will be my first attempt at a soft tail so may need a bit of guidance. Regards,Tink
Hi Barry. Great looking trike.As ive said before,im using a reliant axle. Do you know if i would have to turn the axle upsidedown.When i built the CX500 trike,i didnt have to as the engine rotation was correct for the axle but,im not sure if its the same for the GL1500. Regards, Tink
I will not Give up !
Barry Nunn Happy 2011
hope the new year finds you well and doing well.
and Back with us.
Nice job Berry, really looking good. Man am I envious of your shop as well.
Discussion Starter #232
:waving:hey guys , sorry i havent been around for a while , had a few problems , but im still fit and healthy, my build has been at a stand still for 6 months, but im back on it now that the weather is warming up , ive had to pull the back end off again and fit new disc s and pads ,im rebuilding the calipers , as the brakes were sticking on and would not come off :X,
i had also forgot my pasword so i was having trouble logging in , Drrrrr!
Great to hear your back posting your build Barry.
GLAD to see your back & OK!
What have you been up to?
How's the shop?
Did you get married?
YEAH!!!!!!!
Glad to see you back and that you are doing well dont scare us like that agian.
Well lts see what you been up Too.
Discussion Starter #236
:ROFL:ha ha , quite the oppisite skip , we spilt up 7 month s ago , , just had lots too sort out , like the house and stuff , but hey were still the best of friend , just fell out of love , life goes on,:?
Discussion Starter #237
back on the build , spent the weekend rebuilding the backend, the brakes are working fine now , new pistons and seals, pads and disc s , skip will tell you , its a very hard job with the callipers,:X
Looks good Barry glad to see you back at ,Keep up the great work,
Great your back on the build Barry,looking good.
I ve junked the rear brake pedal on mine and fitted K twin levers with braided steel hoses throughout,cant believe the improvement.
Discussion Starter #240
very nice , looks expensive , did you have to import the unit ?
had the bike out for a test drive of the brakes , and there spot on ! worth all the hard work:smiler:
