241 - 256 of 256 Posts
Hey, let's see some info & pictures of the E-Bake setup.
Still need to figure out one for mine.
barry nunn wrote:
very nice , looks expensive , did you have to import the unit ?
had the bike out for a test drive of the brakes , and there spot on ! worth all the hard work:smiler:
The levers are made in Sweden by RRG i think the company's called.Kliktronic's the UK importer.They were purchased and paid for by NADB...disable bikers association...they give adaption grants to keep disable riders on the road,which im a member.I ve also cut the engine bars down and bolted on footrest so can ride stretched out now Which really helps with back and leg problems.
Great you got out on testdrive in that lovely sunny weather we had at weekend:cool:.Junking the rubber hoses for braided steel really make a difference dont they.
Discussion Starter #244
took some pics the best i could with my phone , the bike has temp lights on it , as i need to keep the weight down for the mot test, and then off to the dvla for an inspection , then i'll bring it back ,put the body on and paint it ,
hey its got wheels on
having trouble with the indicators , everything works but the indercators ! any ideas , ????
barry. looks good
i ran a seperate socket and spliced the hot to the turn signal that was in the trunk and made a new groud for it both sides. and left the run and brake light's on the bike circuit
Discussion Starter #246
yer , but the turn signals have never worked , when i bought the bike , the guy told me there were not working , i ve had the switch apart and the wire are totally dead, also the lower fog lights , down by the crash bars , they are not working either? :?
1st - CHECK the fuse.
2nd - check the GROUND
3th - check the bulbs
4th - check the flasher unit.
5ht - check the wiring for brakes in the HOT line
Corning lights, check the relay
HEY!!!!!!:sadguy:
Your on the wrong side of the street!!!:ROFL::ROFL::ROFL::ROFL::ROFL:
So how it go?
Hey barry, congrats on yer ride looks Good.
hey on the signals mine would not work after I took the trunk off but when i plugged it all back in it worked before.
The front turn signals woul just fash quickly and not the rear while the trunk was off.
Discussion Starter #251
hey the bike rides nice , the standard coil over springs are really soft , i was not expecting it to feel like that , had it over at the mot testing station today , and it pass, just need to ajust the hand brake alittle more, im hoping to get it over to the dvla , some time next week to be recatorised from a bike to a trike , then its road legal , then i'll put the body on and paint the whole thing , not looking forward to it tho !, there s about 30 pannels to paint :sadguy:
so you used the stock shocks from the jag? just one on each side right?
Discussion Starter #253
no i used the stock springs from the goldwing , but i had to buy another off ebay, so i would have a pair,
OK! What happen to barry nunn this time?
It's been 2 monthes:?
Yes Im wondering the same Skip 20 ?
I really hope it because he has started riding the new trike and haveing so much Fun and just hadnt stoped to make a post!!!!!
hi barry
why are you trying to keep the weight down for the mot? your scaering me as im also building a 1500 trike and didnt think there was a weight restriction for trikes.
glennuk
