141 - 160 of 256 Posts
Look again at your mounting . You are pushing up in the center of your lower arm . So you have equal pressure to each side ( inner / outter ) of the shock mount . IF you move the lower end of the shock as far to the outside as possible ,you will increase the leverage . I think I am not explaining my self to well :sadguy:. I think the way I see it , the closer to the inboard hinge point of the lower arm the more you are trying to push apart two objects which are bolted together and imovable .
Think of this . If your lower shock mount was mounted on the inboard hinge bolt , it could not left at all because the bolt is fixed to the upper frame . The more you move the lower shock mount to the outside the easier it should lift . The maximum would be to mount the lower shock mount to the outer hinge bolt . Sorry for my rambling on . I hope you are able to solve the problem .
Discussion Starter #142
got you, i know what you are saying , and skoto1 has said the same thing , i will give it ago , on sunday, thanks lads:)
Discussion Starter #143
yer , my body is arriving in the dock on tuesday , then around a week to clear customs, sould have it soon , :smiler:
Discussion Starter #144
nothing to report , the body is ment to be getting delivered to mine on tuesday :cheesygrin:, and im waiting for a few bits off ebay , l:sleepy:
hi i am in the process of buying a 1500 engine (new) on a pallete, where could i get a electric control for the 6 pot+ wireing loom ? i dont know which engine only it says 1500
I want to take out my 1100 and put in the 1500 but I need the electric control wireing loom that controls the fireing secquance of the plugs?
Hello and Welcome Micky . Thats quite an undertaking your thinking of . The two bikes are so completely different . The 1500 engine is much larger and mounts are not compatable . But let me never say never . I would recomend you get the service manual for the 1500 and see all the electronics you need . Then go looking at your local bike breakers or begin searching on Ebay or similar sites . Personally I'd just recomend you find a 1500 with a tired engine . Here is a link to my favorite ebay source for Goldwing bits , though he is in the USA ....A&D Cycle ----Anthony
Best to you in this project .
Discussion Starter #149
hi you have you work cut out there mind, have you heard of md goldwings the guy is called martin , he only brakes wings , i hapen to know he is brakeing a 1500 now give him a bell on 07521286497, he will help :)
Welcome to the forum Metal Micky......May I suggest that you take some pictures of your project, and start a new thread....This might be something that other members may be interested in seeing....
Claude.....
Discussion Starter #151
HEY any of you guys reconise this body?:cool:
it's here and in one piece, and its not that far out , should not be to hard of a job,
well its all coming together,and on the trike already:cooler:
Hey that body does look like something I've seen before.
That's great it fit first time.
Looks like you may be able to glass in the extra trunk part also.
Get in touch with me for any help.
Body really transforms the look,your well on your way now;)
Barry , the body looks sweet sitting there . Did you solve the rear shock issue ? The newest photo seems to show the upper mount has changed .
All you home trikers are making my welding hands itchy to pull the trigger on one of my 1500s .
Discussion Starter #157
im waiting for another stock spring,from a 1500 off ebay, im going to go with one either side, as there quite strong and if i need more because of the weight of the body and top box ,then i can add an air shock to each side too,
the top mounts have changed , there longer , as i move the axel backwards last night ,to sit in the centre of the body,im not to happy with them as there just temp, plan on makeing a stronger top mount and also fix the front of the diff and fix to the bottom ,
now i need to re-cut the axels again this body is 57" wide, there was a mix up somewhere , as i thought the skips body was 60" wide, so my axel is set at 59"wide,
but hey ,it keeps me busy, :)
If you've got fibreglassin to do,they do a resin that gives off alot less fumes:sick: when mixed with the hardner.It's what they use when using inside buildings,churches etc.The supplier gave me some to try when i did the exhaust lips on the lower rear spoiler.Boy was it alot more pleasant:smiler::smiler: to work with.
IF your axle is wide could you not find a wheel with more offset instead of cutting all your axle parts a second time ? Perhaps a set of fender flares would be good solution as well . Maybe Skip could fab some up at less cost then the cutting . just some rambling thoughts
Wow, I think I've seen that somewhere before. Looking great. What a body can do.:clapper: You still got your work to do, but that just makes it come together. But you need to knock out some walls :ssshh:and give yourself some more room :cheesygrin:
