My 2000 GL1500Se has had a small antifreeze leak in which it will form about a 3 inch diameter drip on the floor over a couple of weeks. I've removed the tupperware and took a picture of the water pump. It appears the 2 small tubes are wet but I can't tell if it's coming from the larger Y hose above it. I've read where mother Honda left tape on the fittings but I have not checked for that yet.
The bike has almost 70,000 miles on it. Do you think it's the hoseor pump? Should I just go ahead and order a new water pump and replace it even if is the hose connection? Give me your thoughts......
