After a short ride to the store and back everything was fine till I later wanted to garage the bike.Turned on the switch ,nothing ,dead.Checked the kill switch (ok)..Got the manual out ,it said check the 2 main fuses,both were OK,checked the battery,it still has juice in it.I'm at a loss...Any Ideas will be welcomed thanks...JERE
PS My wing is a 2001 with 93,000 miles on it and never had a problem of any kind.....
When you say the battery still has juice in it do you mean you measured the voltage? And did you turn the key on and measure the voltage with a load on it?
I Didn't measure the voltage I held a small lite to the terminals..Turning the key shows nothing as it is completely dead...
I forgot to mention to check the battery connections but your test light will tell you not much. If you connect the test light and turn the switch on however and the light goes out or dims that would tell you the battery is most likely dead.
OK..I think I found the problem,the battery is shorted out.I put my charger on it and it registered a short in the batt. Tommorrow I'll get a new one...
