1 - 14 of 14 Posts
Hi all
I have a 2008 model 1800 CSC trike which has just been registered and has only 3000 miles on the clock.
Today we went for a ride and after about 150 miles the the engine just stopped firing as though I had press the kill switch. I rolled to a stop and tried to restart the engine, it fired up and I thought all was well but after about 50 yds it stopped again. This happened about 6 times and I eventually had to stop and call the break down service up and get it trailered home.
I have run the bike in the garage and fisrt time it ran for about 3 mins before cutting out. Second time about 10 mins so I took it out for a ride round the block and it seemed ok.
My wife said that she saw the F1 light come briefly on when the engine stopped.
Not sure if the problem has cured its self, not keen on going on a long ride to find out.
Has anyone had a similar problem and found the cure, any help would be welcome.
Mike
Piled Higher and Deeper
2008.. 3000 miles.. warranty??? that is where I'd start...
Hi MIke,,,Geordiemuppet, has a csc trike,and just the past few weeks ago something ,very much the same occur ed,,it happened to be ,when HGB were building the trike,,they made a poor job of disconnecting the side stand switch,,,,,,and it caused the same problems,,,might just be worth while checking that side stand switch,,,:waving:good luck pp
If not the side stand switch like PP mentioned (if it is the "S" light would come on and it would run in neutral), it might be the kill switch or a loose battery connection.
I am the Hobo
As PP says, Christine had a similar failure about a month ago and may have had the same last year. The trike kit installer removed the side stand and bodged the wires. The problem was a loose connection, simple as that, just not so simple at the time.
I am the Hobo
the problem i had was that the engine kept cutting out the S light did not come on . it would start and then when i put in to gear it would cut out still no S light this happened three or four times.i pushed it a little way along the road then tried again it started and ran for a few miles then the revs started jumping between 2.5and 3 thousand revs then it was just cutting out all together at no time did the side stand (s) light come on. i think this is worth you checking out and eliminating it as a problem.
I am the Hobo
Mike,
I see you are just up the road from us.
You are welcome to pop down any time for info/tips on the CSC or just a chat and a brew - drop me a PM. Note, from tomorrow, we are away to the British Treffen for a week, but will respond when we return. :)
Paul
Discussion Starter · #8 ·
Thanks for the prompt replies I we check out the electrics and hopefully find the problem.
Unfortunately the bike is not under warranty as I purchased it from GP trikes in Ireland who imported from the States so Honda do not want to know.
Many thanks
Mike
My mistake on the S light, I assumed they would have just left the switch in place and turned it to the up position. If they failed to get a good connection between the green and green/white wires it sure could cause a problem.
The Irish Crew
Kill switches on the first gl1800s were a problem but they fixed that. A bad bank angle sensor would make the engine cut out but hardly on an 08 with low miles. Bad petrol is another possible as is a bad sidestand switch.
I have heard of sidestand switches going bad on quite new gl1800s and it does seem a possibility.
Discussion Starter · #11 ·
Well I have now checked out all the electrics - battery connections were ify but are now good and the side stand switch was still connected, so I made sure that it was in the right position.
Ran the engine for 10 mins and all seemed to ok so I went for a ride and after about 15 miles the engine cut out briefly and the FI warning light came on for a few seconds. This happened a few times on the way back home but it did not completely stall.
Prior to all these problems occuring I did top up my tank and the cutting out problem started about 20 miles latter.
Could it be some bad petrol? would the FI light come on if this was the case. Any further thoughts anyone before I take it to a dealer and spend a small fortune.
Mike
Discussion Starter · #12 ·
Hi just an update, the problem was finaly found to be caused by the alarm system that was installed when I purchased the trike, a requirement for insurance purposes. When this was finally disconnected (process of elimination) all has been well for the last 300 or so miles.
I have seen no end to problems caused by aftermarket alarm systems. It is usually the installer, not the system.
Exactly.... and then there is after market trailer lighting, lighting in general, sound systems....Xm, IPod you name it. Any aftermarket electronics installed a bit wrong has made headaches for manyvehicle owners. Can't always trust the dealers - installers. I would rather make the mistake my-self and learn.... than pay some monkey to hide a gremlin for me to find later. But itdoesn't always work out that way! Oh the friends car's and bikes I have worked on!!! Don't get me started!:shock:
1 - 14 of 14 Posts
