1 - 3 of 3 Posts
G
Guest
I have a friend with a2002 GW (non-ABS) and while on the road, all his instruments and taillights stopped working. He replaced the fuse, turned on the switch and immediately blew the new fuse. Any suggestions for troubleshooting or the cause?
Sounds like a direct short to ground at some point. A wire rubbed and touching the frame. Or ground and power wire shorted together......
Hard to find as meter will show continuity even through the short.....start at the tail light bulb sockets and go from there.
Kit
G
Guest
Kit,
Thanks for the response. Will start with the taillights and let you know when we find the culprit.
1 - 3 of 3 Posts
