is this a new problem or did they ever work ? Are the calipers mounted higher than the master cylinder?JB
A bleed down test would confirm this theory. Hold the rear brake down for a few minutes. If you dont get brake fade, The system is intact!Off the top of my head im going to say you might have to look into putting a 2 psi residual valve. inline . You normally dont need them with disc brakes as most the time the the calipers are lower than the master and stay full. There is a chance that fluid is flowing back into the reservoir by means of gravity requiring to pump them up. . . JB
