1 - 14 of 14 Posts
Change the stator on my Goldwing, I was wondering which yellow wire goes to which yellow wire or does it even make a difference.
1993 GL1500 Aspy 1980 GL1100 STD
Nope, Doesn't matter which to which.
Connect yellow to yellow, then yellow to yellow, and then yellow to yellow. It's AC there.
When you connect the wires use a automotive style 3 wire plug, has heavier connections to handle the current loads better and saves the stator.
2012 GL1800
The best way is to eliminate the connector altogether. Solder the wires, heat shrink and tape them. Never have to worry about a burned plug again.
1 - 14 of 14 Posts
