You have to find out if it is loosing spark or fuel. When it runs bad disconnect the plug wires one at a time and see if you can isolate which cylinders may not be firing and if there is spark there at the time.
2007 1800 Crucible Orange
Hello and Welcome to the forum family . Start the bike from cold . after say a minute of running, spray / sprinkle a bit of water on the header pipes ( touch with a finger if your so inclined ) to see if any of the pipes stay cooler or cold compared to the others . This would let you see which cylinder s are not running . If this test shows a cold cylinder then you must determine if its lacking spark or is it not getting fuel .
Have you checked the plugs , spark ? Replaced the fuel filter ? it may be starving for fuel if it runs well at start up then looses power . The gas cap may not be venting and this can also cause a starving for fuewl issue .
I have never had one fail, but if you search here you will find lots of people that claim to have had failures.
That said, I have had 'failed' ones on bikes I have purchased, and have found loose/bad wires or incorrectly installed systems that I was able to make work.
A few years ago I had one on a 77 and the thing would barely run, as the installer did not install the ballast on the coils. The ballast was in a box of parts that came with the bike.
For someone that can't set points correctly they are a good way to go, but the stock points are just as good for those that can work with them.
Some people hate them, others love them (like me).
Bill
1993 gl1500, 1976 gl1000
Actually it was a very common problem with the older units. I have had one fail. Supposedly they have solved the problem. ???
