Hi all I took the battery ground cable off months ago and I forgot where it attachs to the frame or engine. Can someone tell me where, I have it temporary attached to the frame at the motor mount.
Hi MS, why would you consider that temporary. Does everything operate as it should? If so it's fine. The ground connection can be any area free of paint and preferably a little beefy to handle big current conditions like starting. It's not mandatory where it goes, unless the routing hampers something else.
No good John
Thanks guys, while attached to the lower mount it started smoking and got hot i think it was because of the paint in that area.
Thanks again got it in the right spot.
