OK, now this is a bit strange. I offered to help a friend get his "Classic" running again, maybe a winter project. So we pulled off the carbs to clean and repair. When the tops of carbs came off and were numbered for replacement the carb slide springs were different lengths and number of coils on 1&3 as opposed to 2&4.
Is this a result of some hack repair job or did Honda mix and match these springs.
If they should all be the same where do new ones come from?
:confused:
They should be the same length. Not only that they should have the same compression force, with a mismatched set like you describe I don't see how you could balance the carbs at all. You could try Randakk's Cycle Shack website about springs. He's really the top guy for GL1000s. He dosen't list the springs on his site but you might send him an email, it's pretty likely he could come up with a set.
1993 gl1500, 1976 gl1000
All gl1000 springs are the same. Hack job!
pistol pete might be able to supply some too.
