Hopefully there is someone out there who can give me some advice. :praying:
I got my 1979 GL 1000 last December. I haven't had any issues with it until today. I went to go to school, turned the key and everything was normal, dash lights lit up(oil and neutral light), headlight came on, everything was fine. As soon as I hit the starter button, everything died and now nothing comes on when I turn the key on.:?
I have checked the main fuse by the battery and it is good. Any ideas on what I should test next and how I should test it?
I'll save the advise for later. Sounds like dirty or loose battery cables/clamps. The draw from the starter probably opened the poor connection. Clean, tighten, and try again.
Okay, I feel pretty dumb right now. :sadguy:
After cleaning the battery cables and clamps I decided to test the voltage(the battery is a year old, I ride the bike almost daily and have a battery tender on it when I am out of town and not taking the bike) so I figured that wasn't the problem. Before turning the ignition on I got a reading of 10.95 V and after turning the ignition on it drops to about .5V. It doesn't make sense to me that its the battery since I rode it earlier today with no problems....Does it sound like its just the battery to you or something more and the battery is just a contributing factor?
have you check stator output?
check that and the connections the three yellow wires forwrad of the battery box.
· Registered
sounds like loose connections at the battery to me.
