Ladies and gentlemen: I am happy to report that the GL1100, 1980 is now road worthy and I have put on 40 Km in testing it. Part of my problem is expectation; I expected nothing so everything above and beyond zero is a bonus. The wing rides fine, I have to readjust the suspension since 19 PSIG up front along with 42 PSIG in back is too truck like. At 100 Km/hr the tach reads 3800 RPM. With a standard bike of this vintage is this about right? I did note that the people with 4 wheels are in much more of a hurry than I am, so I really do not know if the speedo is correct. I will examine it as time goes by.
The fairing is solid as are the bags, no undue vibrations. After the run the carbs seemed to settle in with distinctive pulsations from the exhaust along with an idle at 1100 more or less. The new Havoline Coolant (Extra Life Red) kept the temp at the beginning of the normal range at highway speeds and smack in the middle in town. I am still running the fuel I put in during the repair sequence. Voltage stays at 14.99 to 15.02 max at the upper rev range. Clutch, gears tranny and output shaft are stable, quiet and act as expected. The engine is quiet but at times the exhaust seems slightly noisy. No leaks in the exhaust area and so far no leaks in the engine, oil, and coolant area. The engine takes a load quite well as it does the higher revs. I maxed out at 100 Km/hr (62 MpH) since this was a test.
Having been off a bike for 10 years my expectations of noise, vibrations and handling became normal after the 40 Km run. It was a test of both the bike and the driver and we both passed. Tomorrow I will hit higher speeds to complete the testing then dump the oil and send it for a chemical analysis
Again thanks to all for the help and assistance.
