I took these two statements from another thread to help you get an answer.
What I need is for someone to tell me what wire exactly do I need to splice , from a 1983 asp motor, to fit the harness of a 1980 gl1100 standard. Can you help me with that?
My only problem now is to make sure I connect the neutral switch to the proper wire, mine is standard the newer motor had digital dash. Neutral switch is in different place with 6 wires going to a connector, mine just had the one wire going direct..... d.k.
The neutral wire is green.
Glad I could help.
