1 - 17 of 17 Posts
Does the fan run continuously or does it go on and off based upon some type of heat sensor or thermostat? What are the steps I should take to troubleshoot. Thanks.
There is a thermo switch behind the thermostat housing. Look in behind the upper front engine mount plate from the right side of the bike and you will see it there with a 2 wire plug in a rubber boot. It's kind of hard to reach, you will have to remove the right fairing lower. Pull the plug off the switch and jumper the 2 wires together and it should run with the switch on. If not check for power on the connector to the fan motor, access it from the left side.
Guru
If your fan works when you jump the wires you can rig a toggle switch to it until you buy a new temp sender unit.
Fan turns off & on when engine needs cooling. It will run while in stop & go traffic but should shut down on the highway.
Fan should come on when temp gauge is about half way in it's operating range. If it doesn't shut bike off, unplug connector at the thermo sensor not the fan. Jump the connector at the sensor plug & the fan should come on. ( Make sure the ignition switch is on when doing this). If the fan comes on in this fashion then its the thermo sensor switch.
Do a search on the site? Many ( me included) have used the 94 Geo switch as a replacement.
Yes your have to be careful. The switch has to be from the 92-94 Geo Metro or Suzuki with the 1000 cc engine. Later models went to a smaller threaded switch.
I would suggest you take your old wing switch with you and match up the threads. Don't worry about the connectors as you have to make some up.
Do a search on the site lots of info on this thermo switch.
Got it. Thanks to everyone. Old hand at working on cars but new at working on bikes.
Well, you going to let us know what you found or keep us guessing?
Sorry for not responding on the results. I took off the boot on the sensor, jumped the wires, turned on the ignition, and the fan came on! Apparently, the fan had not been working since I've had the bike (noise is fairly noticeable), but had only been riding it in colder weather which is why it probably never ran hot.
Since there is not very much wiggle room to take out the sensor, and I've heard horror stories on stripping bolts, I'm theorizing I will need to drain the coolant, take off the radiator and fan assembly, remove the seat so I can remove the covering containing the tool box tray, etc. The alternative would be to purchase a large enough socket to go over the sensor and take it out from the right side.
Am I on the right track? Any suggestions?
Guru
If the rad is in the way, you might be able to un bolt it & move it just enough to get at the sensor. Dont forget, you can rig a toggle switch as a temporary on/off until you get to doing the repair.
Discussion Starter #11
I have considered a toggle switch, but would prefer to go ahead and make the repair since there aren't that many good riding days yet.
But I'm thinking I will need to drain the coolant before taking out the sensor, right?
One final question, that will save me time on reading the manual, how does the seat come off? I see the slide adjustment. Do I unscrew these bolts on both sides to take the seat off?
A 1 1/16" deep socket will go over the stock temp sensor. You won't have to remove anything but maybe slide the horn out of the way.
I don't know the metric size but I know this size works as I used it on mine. The Geo switch is a smaller size but I know I didn't need a deep socket to put it in.
Just drain the antifreeze down until its below the thermostat.
Discussion Starter #13
Okay, I will get the socket. I had already removed the horn out the way to get to the sensor boot. It seemed like there was enough room to slide a socket into the area besides the black brace that appears to be mounted to the engine.
After I drain the coolant, can I refill through the overflow tank, or do I have to take off the top cover (what looks like the gas tank - don't know real name) and fill through the fitting that has the radiator cap? And if I have to fill through the fitting, how do I take off the cover, etc?
Guru
Ya, you gotta use the rad cap as your port of entry. That top cover gets refered to as a false tank.
If you pull that off than there is even more things you can check while it's apart, Like your air filter. Some wings can be stubborn to burp the air back out of the system which can cause the wing to overheat.
Use only low silicate coolant in your bike.
I was just thinking. If you've never ran the bike when its warm or idled it long enough to get the bike really warm, how do you know the thermo switch is defective. Just a thought.
If you do go the Geo switch route, go to a local auto wrecker & get the sensor & wiring connector from a wrecked Geo of this vintage. From what I've seen the wiring from the bigger engine has the same plug end. Using the Geo wiring connector will make it much easier to put it into the wing's wiring. You just have to put to male plugs on the ends & they will plug into the old switch wiring. Cost me $5.00 but made the job simple.
When you get around to putting the antifreeze in, I would completely drain out the old and put in new. Fill to the top of the rad & keep filling until it stops taking antifreeze. Start the engine, the level will drop, add some more until the level stabilizes or starts coming up. Then put the rad cap back on & fill the overflow tank to the top mark. Run bike until top rad hose is warm/hot & the fan cycles on & off a couple of times. Shut down engine and as it cools it will draw fluid from the overflow. Next morning top up the overflow tank to the top mark. Keep an eye on the overflow tank for a couple of days to make sure there are no leaks.
That's about it.
Discussion Starter #17
The bike had been modified when I purchased it. The prior owner had taken off the instrument cluster among other things. I road it some without the instrument cluster and just a digital thermometer he had installed. I had a guy do some work on it and had him reinstall a some of the things that were taken off to include the instrument cluster. That's when I started noticing the temp climbing up. I've been lucky that I never rode for long or in traffic.
I will follow your suggestion and check with some salvage yards for the sensor and the wiring. Thanks.
1 - 17 of 17 Posts
