1 - 9 of 9 Posts
No I have not checked for power to the coil as I am working outside and it is raining but thanks for the tip. I will check as soon as I can.
· Administrator
It is probably not a coil unless it's both. One coil fires #1&2 (front cylinders) the other fires #3&4 (rear cylinders. Check the plug wire connections at the coils and spark plug caps.
also check the plug where it pluges into the main harness from the pluse generators .
yeah switch the spark units around and see if it fixes that one to fire be prepared new ones cost a bundle..... try a used bike store or maybe ebay
1 - 9 of 9 Posts
