61 - 77 of 77 Posts
1981 Honda GL1100 Goldwing Interstate
Discussion Starter #61
So I'm guessing you don't believe the breaker will work?
Since I already have it I may as well use it.
What I like is if it does trip in 30 seconds it re-sets. Where a fuse when it blows it needs to be replaced.
The breaker should be OK to use.
Discussion Starter #63
Back out in the barn.
The bike is cranking over fine...It will fire if I spray ether in the carbs.
I opened up the fuel pump and cleaned it and it is now pumping fuel.
When I pull the plugs all 4 are dry.
I can believe all 4 carbs are plugged, so my question is ....... is it.possible that even though the fuel pump is pumping, could it not be pumping enough pressure? Does anyone know how much pressure the pump should be pumping?
If it's pumping it's enough. It can't pump less or more pressure than it's designed for. If the bike has been sitting for a long time the carbs are plugged up period.....
Discussion Starter #65
I just got done cleaning the carbs.
All 4 carbs were removed and put in an ultrasonic cleaner....new float valves...all ports blown thru new low idle air screws.
With all 4 spark plugs being dry I can't believe it's the carbs......maybe one of them wasn't clean well enough but I can't believe all 4
1987 GL1200 Interstate
If it runs when you give it fuel from an external source, the pump isn't working or, the pump isn't getting fuel.
Or...the hose from the pump is plugged.
Discussion Starter #67
Tomorrow I'm going to get some new fuel line and a cheep 12v electric fuel pump.
That should at least eliminate the fuel pump as an issue.
If the fuel pump solved the issue, I'll do the conversion to electric pump.
02 GL1800 w/Auto Pilot
Be very careful with that Electric Fuel pump.
be sure it is 3.5 psi MAX, some of them push 10 psi or more, and will flood the carbs/engine cylinders.
Discussion Starter #69
Thanks for the tip ...... I did find on some other posts of people doing the Electric pump conversion that they are using a 2 to 4 psi "low pressure" pump. I didn't see any that low on the websites of my local parts stores so I ordered one off Amazon, I should have it tomorrow.
1993 GL1500 Aspy 1980 GL1100 STD
Maybe the pump pushed some more gunk into the carbs, you may have plugged needle/seats.
Discussion Starter #71
It's alive!!!!!
Now I need to decide if I want to do an electric fuel pump conversion or get a new mechanical fuel pump.
She is idling a bit rough, but if it's running I am guessing it can be tuned. My question is the air screws......they were set at 2-1/2 turns out but factory is 1-1/2. If I move them to 2-1/2 out will it have an effect on the idle?
Thanks to everyone for all their help.
Those screws are set through an idle drop procedure. Call it a tune if you like but it's not easy and requires an electronic tachometer. Have you done a vacuum balance yet?
Discussion Starter #73
I was just able to get it to run...I figured before I start messing with the tune on it ...... I would get some feedback from this forum......but I did not mess with the screws that are between the carburetors..... the yellow paint marker on the threads is still there.
They need synchronized anyway especially since you have had the carbs apart.
Discussion Starter #75
I ordered a 4 gauge sync kit from amazon.....I should have it tomorrow.
I'm hoping it's as easy to sync the carbs as it looks on YouTube.
I just keep diving further in this rabbit hole LOL
Often these bikes are not as expensive to repair as the tools needed to do it! 🤣 MORE TOOLS! 😁
Discussion Starter #77
Luckily my wife has the attitude that a tool can always be reused and not a waste of money..... I almost never hear her complain about me spending money on tools
61 - 77 of 77 Posts
