Greetings,
I bought a replacement water pump, but it does not come with the shaft seal that presses into the block. Sounds easy to find---right. Wrong. The Honda parts guy (and myself) cannot find the part on any of the micro-fish.
Does anyone have the part number of that seal?? Thanks, Lew
Lew do you mean the large o ring, part no 91303-283-000 wich is 37.2 x 2.3 dia hope this helps.:waving::waving::waving:
Hi,I've recently replaced my seal and it was an easy job,just freeze the seal first it makes fitting it in the housing easier.Not 100% certain but I'm sure the seal is available seperately for the CX500 (part no.19217-611-000).Good luck hope you solve it.
p.s.Think there is a mechanical seal on Ebay at this very moment.
Greetings, (again,)
No I mean the pump shaft seal that presses into the engine block. Do you have that number? Thanks again, Lew
91207-580-003 Check that one. I "think" it's the correct one. I believe you'll find it in the oil pump breakdown.
Lew, let me know if you need this seal. I have one spare that I didnt need when i did my water pump. If you want it, PM me with your address and its yours.
That would be great. I would be more than happy to pay you for it.
Lew Daniels
1750 Dammeron Valley Dr. E
Dammeron Valley, UT 84783
