It probably only needs brushes and a cleaning. Do a search for starter removal, probably is in the post index.
:waving:When troubleshooting a starter problem start at the terminal on the starter and check for voltage at this point while pushing the start button. If you have voltage at the starter, roughly 10.5 Volts, then there are problems with the starter whereas if there is no voltage at the starter then go to the solenoid.My 83 GL1100 had similar symptoms...The solenoid went click click and nothing....folks here advised replacing the solenoid which I did last week and now she starts like a charm. Hope this is the same solution for you.
