1 - 3 of 3 Posts
84 1200 standard
Hi my 81 gw front brake will not pump strongly enough to push brake fluid to
The caliper the bike has been in storage for 8yrs so maybe clogged up under
The resevour the plastic resevour will turn but it won't come off to see the ports
Below. Is it meant to come off the brake handle I am afraid to snap the plastic
Any info on this?
Thx Gumby
Yep, it just pops up..there is an o ring at the base that's all that holds it in place..I use a putty knife to get it started push it in all around the base cut though the crud that may be there....and then pry a bit until it starts to move then wedge with something fatter..and pull..
1 - 3 of 3 Posts
