1 - 3 of 3 Posts
I did a rebuild on engine, new starter and relay, new reg/rectifier and new battery. Startet relay just clicks but starter doesn' t kick over. I removed starter and it does work when activated thru the start system. I can rotate the engine via the 17 mm nut on the stator, harder with the plugs insalled , easier with plugs removed. I can,t seem to locate the selenium rectifier that is in the wiring diaigram. Anyone know exactly were it is located? Battery is at 14 volts.
I could use some tech help!!!!!!
Ben
I would be looking close to be sure you have a good ground is the ground wire attached that goes behind the left triange engine bracket? use jumper cables from the starte rcase to theneg.lug on the battery and see if that helps.
1 - 3 of 3 Posts
