1 - 3 of 3 Posts
I started a rubuild on a 1981 GW starter rebuild. After I got it apart I noticed that my 3 washers on the front and back of the Armiture shaft were missing. This caused metal casing shavings inside the starter. I looked in the Honda Part supply for these 2 sets of 3 washers and could not find the parts. Does anyone out there know what the measurements of these 65 washers are and where I canpurchase 2 sets of them at?
Thanks for your time
jblace
P.S. - I am getting tired of push starting my bike :(
If it were mine, I'd just get a new starter. I got mine on ebay, works fine, was like $110 or so?
Hi Jblace,
When I "refreshed" my starter I had all 6 of them. In total they would have been about 1.5 mm in thickness. No more. So if you can come across 4 smooth .75 mm washers you shoud be fine. Put two on each end with a little grease on them.
It had been working up to that point.
Washers are cheaper then tossing out an O.K. starter.
Tim.
1 - 3 of 3 Posts
