Hi all new member my 1100 just got it well have a problem start's fine idle's great
take's thottle good after it build's temp start's to miss than losses 1 or 2 cylinder's let it cool down and it will repeat the same could it be cdi or coil's please help a thread by a guy called tweak on here had the same issue but
never solved the problem any info would be great Thank's cleveland :sadguy:
You posted this in the "forum support" forum so not too many people will see it here. One of the mods will probably move it, but you would be better off to post this over on the Technical Forum where all the "Guru's" hang out.
By the way, welcome to the forum!
Magic Moderator
Hello and welcome to the forum.
Have you tested the Pulse Generators, one may be experiencing thermal breakdown and dropping out.
