1 - 3 of 3 Posts
how much deflection should belts have??i have about 1/4 inch play on the belts.to tight or to lose???
Sounds about right but they should adjust themselves if you installed the belts correctly..crank on T1 compression stroke for #1, tensioners lose..2/4 side tighten tensioner..1/3 side rotate cam wheel 180..belt gets tighter on up then tighten tensioner.
1 - 3 of 3 Posts
