Yep that's the one, the cross pin on the switch has to fit into the yoke on the transmission. You need to have the tranmission in neutral and set the switch to neutral before putting the cover on. A simple way to check the switch position it to connect the switch to the bike's harness before you put the cover on and with the ignition key on turn the switch until the neutral light comes on. You can also check the position of the switch by using an ohmmeter. Just turn the switch until you see continuity to ground (0 ohms). Be sure to put the cover on straight onto the case, don't move it sideways or up and down much or you may misposition the switch. It's also important to align the waterpump shaft with the tip of the oil pump shaft before placing the cover on the engine.
