1 - 3 of 3 Posts
When advancing the throttle past half travel, engine boggs down. When I let up a little, the engine begins to respond. I've synched carbs and thought I did the floats correctly. Almost seems it's getting too much fuel.
Welcome to the forum Johnny nogood
Have you replaced the fuel filter? Napa #3011 @$5
Have you measured the fuel in each bowl?
What is the history of this bike? Has it run correctly for you recently?
mr irrelevant
When our 83 did that, accelerator pump gasket on carbs was torn...replaced that and cleaned carbs, problem solved...hope this helps!!
1 - 3 of 3 Posts
