Hi everyone, I have just completed a rebuild of a 1982 GL1100 standard. I have installed an aftermarket Speedo but I am having trouble with the wiring. Can anyone tell what colour goes to what please? This is the last bit of the build. Thanks.
Photo is of new Speedo wiring.
323422
All those match up to the colors in the bike wiring but where it has a temperature light won't work with the temp sensor on the engine, it is for a gauge. And I don't see an oil light.
Thanks Dave, I have the main issue I have is the backlight and the neutral light are not working. The speedo has a limited display. I have installed a temp gauge on the tank so this is on separate wiring.
Are you sure of the neutral switch and is the unit grounded? I don't see a ground wire noted.
In that case you have everything it needs so if it doesn't work right it may be defective. Jumper the lt green/red to earth and see if the neutral light comes on.
