I was thinking about riding naked and wondered what I needed besides Headlight mount, and Turn signals.
Senior Guru
a good lawyer i got this guy on camera in barcelona only thing he had was a bag of washing
There's no such thing over here or over there. I spent four years in Suffolk.
1982 naked gl1100
usually it also helps to have a motorcycle hehehehehe
anyway, many of us here are also on nakedgoldwings lots of good advice there about going nekkid
My friend attached a Harley headlight; made a bracket. Also used the horn lugs to attach little aftermarket turn signals.
Scantily clad is an option too. Consider keeping the saddle bags but store the tail bag.
Basically you'd need a headlight assembly, mounting brackets, and turn signals. If you ditch the trunk and saddlebag frame you'll need the bracket that goes around the back of the seat and attaches to the frame and the hole in the rear fender. If you have a Standard then you can easily see the differences between that and your Interstate.
