I would guess it's a good chance the carbs are gummed up. Try squirting a little gas in the plenum. If it starts but doesn't keep running that is the problem.
And compression.Spark is there, air is there, the only thing remaining is gas.
Depending on where they are it will do nothing or backfire. A picture of how you have it set up would help.Dave0430, Dusterdude, and Aktersnurra
QUESTION: With the new coils, if I had the spark plug cables attached to the wrong plugs, what would happen when it turned over? Would it be obvious?
Thanks.
Thanks, Dave. I'll get the picture to you this afternoon.Depending on where they are it will do nothing or backfire. A picture of how you have it set up would help.
Dave, I'Thanks, Dave. I'll get a picture this afternoon
Here's how I have the coils wired:Dave, I'
ve got a jpeg photo on my desktop, but the site is asking for a URL. How do I do that?
That tells me nothing. The black wire should go to the center terminal, the yellow to the front terminal, the blue to the rear.Here's how I have the coils wired:
OLD PLUG NEW PLUG
blk to blk
yel to yel
blu to gray w/red stripe
On the bottom of the page you will see a paper clip. Click on that and go to your desktop and attach the photo. Click on the little down arrow next paper clip and attach.Dave, I'
Or you can just drag and drop the photo to the message composition area.On the bottom of the page you will see a paper clip. Click on that and go to your desktop and attach the photo. Click on the little down arrow next paper clip and attach.
