HI all-
Just replaced the 2 orings and gasket for the starboard side pipe. It was leaking at the pipe/head joint. Now it leaks at the inner oring(near the thermostat). It seems seating the oring on the interface is not so easy. Any tricks?
Thanks in advance
Ken
Went to Street Vibrations in Reno Nevada , Thursday and Friday- lots of hot bikes, Rock and Roll, beer and Babes- check it out if you can!
A blob of grease holds the ring in place. Just make sure the ring didn't get cut by the sharp end of the pipe. :waving:
Thanks Eddie-
finally got the pipe back together, and no leaks! The new orings want to bind, but after 4 attempts, it's back together.
Ya gotta lube up the o-rings slightly and twist the pipe into the flange when reassembling. The lube keeps it from binding or bunching up.
Raymond
