1 - 3 of 3 Posts
on my aspe fairing dash are 4 digital guages.the far left is for radio,far rt is for cb.the middle 2 are marked volts and temp.neither has ever worked.checked fuses all good.i am assuming temp is for outside air temp as has coolant temp guage between speedo and tach.my factory owners manual doesnt mention either one.any body have them on their 82?any ideas on how to get working?
The temperature gauge is purely mechanical and has no wires except for the back light. If it doesn't work it just doesn't work. The volt meter should have power going to it when the switch is on. I think it connects in to the hot wire into the fairing for the radio, it also has to be grounded.
thanks a lot.i have to pull the fairing monday to install a new 7 volt reg., so thought if i knew a little about the guages i would have a go at them as well
1 - 3 of 3 Posts
