I am begining to help my '83 1100. It has sat in a neighbor's garage for about 17 years. It has 33K miles, and never had any major issues. I know I will need to clean/seal the tank, clean/rebuild carbs, and flush brake lines and rebuilt calipers. How does that tank come out??
Remove seat ,saddle bags,top box. Remove saddle bag frame. Remove rear wheel and rear fender. Remove inner fender. You can now see the back of the tank and that is the way it has to come out. Be careful of wireing ,hoses,etc as you remove it.
You can download the manuel for it here in the forum. Welcome to the site.
Thanks... I've removed the seat, saddle bags/trunk and the frame that supports them. You say the inner and outer fender and rear wheel - does the swing are need to come off too?
Evapo-Rust..Clean it while on the bike. Just besure to fill it with gas to keep it from flash rusting afterwards.
Village Whack Job...
It's my understanding that the tank will not come out through the rear of the frae. The motor has to be pulled and the tank comes out that way.
:waving:The engine does not have to be removed to remove the fuel tank. Once the rear wheel/tire, both sections of the fender are removed, wires disconnected from fuel sending unit, tank bolt and crossplate removed the the tank can be moved rearward and out of the frame. This info obtained from my Honda GoldWing 1980-1983 Service Manual.
I'll second the motion, the tank comes our the rear of the bike just like it was giving birth. Don't forget to remove the petcock, it won't come out with that still on. Don't ask.:blushing:
